Razor if your reading maybe you can give me a hand here. The light on my alky kit is always green never red. Alky works fine with no problems. But i remember calling you on a tuning issue and mentioning it and you said to check the ground wire at the pump. I did this and i got nothing. The only time it worked was when i first put the kit on and it worked for that day. While the car is down for the winter and i finally have some time i figured i would mess with it along with other things on my to do list. Unless I stick with the the ol If it aint broke dont fix it, cause alky seems to work fine. Also since the car sat for this winter should i do anything special to assure the kit is working ok, or just push the test button and see if she sputters.
