BoostKillsStres
TIRE-FRYER VIA HAIR-DRYER
- May 25, 2001
I've made the std mods to my chip image(based off the bbkj image) to increase spool, wg dc coeff. and 100% bleed in the low rpm table but now boost comes up so fast I can't seem to get enough fuel to it to keep from pinging off the line or when stabbing the throttle after an easy launch and once into 2nd gear(street fighting
). Once I'm at full boost everythings fine, timing 18 degrees, 02's in the 760-790 range, fp 47 hose off, 340 hot wired pump and 1psi of fp per 1psi of boost at the rail while driving.
I've been adding fuel in the 2400 rpm table, would it be better to get the car into pe a little sooner using the PE tps threshold table, I know I'm basically looking to richen up the pump shot on the car but not sure the best way to get there. It looks as though its going to be a combination of table mods to get there.
TIA,
Mark
87GN
TIA,
Mark
87GN
