Redline tonight!
Spooled231
Hey Guys,
Im going to be heading to Redline tonight to do some test n tune on the car. Come on out so we can have some fun.
John Martin
results
David,
The car did pretty well after fight an electical gremlin thats been there since the first of the year. I thought it was solved after I found a wire off my relay that controls the fuel pump. NOPE...not it as I found out with my first pass
7.35 @ 95
Decided to put the fusable links connection back in the same spot where they were last year. The car ran flawless after making the change 7.15 @ 97 and 7.11 @ 97. The tune is still every mild/ conservative with 19 psi and 20 deg of timing. Still needs some fine tuning in some areas and should help the ET and time a little more once those changes are made.
Ive got some new goodies on the way to tweak the suspension geometry. They will be here later this week and will try and set it up after this coming points race at Redline.
