refill?
trbo6gn
i am thinking about getting an alku injec. kit but i was just wondering how often do i have to refill it. it seems like it would b a great thing to have on the street i was just wanted to find out the answer to this question before i go out and buy the system thanks everyone
ryan
what kind of modds,not that often running on the street,about 8,1/4 mile passes average
i drive this car alot on the street so it wouldn't last me very long would it and how much is it to refill it
You only pump out alky. when the boost is over your 9-10 psi. turn on point for most cars.
You have to ask yourself, self, when on the street just exactly how much time am I over 10psi.?
Not very often on my daily driver. Once or twice a day for brief moments.
My stock 1/2 gallon SMC tank lasts a week in the summer and two weeks in the winter. It's never empty when I fill it.
Obviously you need more when racing.
$10 a gallon roughly for denatured alky. I mix mine about 50/50 with water so it doesn't cost too much.
If you’re running 15 lbs don’t bother using the alcohol. If you intend to run 20 it’s a great alternative to expensive fuel. I am about a once a week fill up myself. From what I can tell you have a pretty stock setup so alcohol probably shouldnt be one of your first investments.
car has alot of mods blcok is bored .30 over with forged pistons,te-44 turbo-3 inch atr downpipe,mafpipe,ls1 maf sensor,adjustable fuel regulator,along with others and on the way within the next couple of weeks will be injectors and a front mount
Sounds like it would be fine with the gallon optional bottle.
Email Steve C. at SMC and see what he thinks.
Oh yea your ready for it. I assumed since you were running at 15 lbs that it had no mods. Start moving that boost up slow until you get the alcohol set right.
