A few questions...Tonight I took my car out for the first time in about three weeks. Normally it starts fine after this amount of time.
1. Tonight it did too, however the BAT reading on the Scanmaster was fluctuating between 11.8 and down to about 10.5. After 15 minutes of driving it stayed at about 10.8 and didn't increase (alternator not charging it?) but it didn't drop either. I would expect it too be higher! The headlights seemed a LITTLE dim and The turn signals also flashed very slowly, but overall driveability seemed alright overall. The battery is about 2 years old, but I've never had issues with the battery voltage readings when the car has sat for a while.
2. I had a code 23 (air temp sensor) but I think that is just because I didn't reset the ecm after disconnecting it last time I had started the car. I did however have a new code 45 that started on my way home (about 4 hours after the first drive tonight). At the same time the INT reading was fluctuating between 100 and 115 (rich). Previously it had pretty much been pegged at 128. The BLM readings have been at 105 (rich) for a while.
I realize that this means the O2 sensor is reading rich. Could this be simply a bad O2 sensor (which I've been wondering about for a while) or simply related to low power in the battery? I had also noticed that the CC's were cycling much more slowly.
3. Finally the IAC was reading about 51 while in gear at a stop light, but if I shifted to neutral or park, it dropped back to 31. In gear it would go back to 51 after driving and stopping again. If I got on the gas a little bit while driving, and then stopped it would sometimes drop back to the idle value of 31 that I was getting in park or neutral.
Are any of these problems related? Or does the car have multiple problems? Mainly it's the low battery voltage and code 45/slow cross count that I'm concerned about.
Thoughts, comments and suggestions?
