relocated iac
idle
Did they give you a remote mount billet piece for the IAC ?
I have one - just buy 2 hose barbs to screw in the end holes for the IAC in and out. Run one vac line from a Tee off a vac line on the vac block on top of the TB. Run the other line from the 'out' port of the IAC to atmosphere or to the MAF hose.
You obviously then need to set the IAC to work properly.
I havent tried mine yet.....
