I`m going to go for a start-up on new eng soon,I`m using a TA49 that is re-clocked to blow towards the front of car,I`m using an adaptor from the spearco IC kit on my intake.I want to re locate my TB to this spearco adapt,that would put a lot of pressure on the TB,was wondering if the stock waste gate in the turbo is good enough to relieve this positive pressure that now will be on the TB when I dont need it. Do I need a BOV or somthing like it ?? I plan on installing my spearco IC later after I get the bugs worked out of new eng/trans ,thinking of installing IC behind the radiator,where the 86/87 is located.Heard a lot of issues with the spearco kit ,and the stock location of the TB ,some say its in the tuning,others say problems are in the location of TB, If the problems are in the location of TB,,then I want to nip this problem in the bud and relocate TB now,but to bleed the pressure off the relocated TB might be a problem for me---Jack
