Remote Oil Cooler?Filter Questions?
clonestocker
I'm thinking about dumping the radiator oil cooler on my son's car. Enlighten us on what options we have on either one or both. thx matt
Summit has lots of oil coolers - check them out.
I just fabricated a mount with four studs, welded it to the frame under the battery, and bolted on an Earl's 41008 - it comes with -8 AN fittings.
Need two 90* -8 AN hose ends for the oil cooler end; this, of course, depends on the location/orientation of the cooler.
For the stock Oil Cooler Adapter/Filter Housing: I used a sweet hose end that also has the NPT to -8 fitting needed for the oil cooler adapter. Earl's 824588, 45* 1/2" NPT to -8 Hose. And it a swivel 45* so I hope it makes it easy to plumb the hose to the cooler.
