I want to remove my front coils and want to know if this is a fairly safe way of going about it; I was going to rest the car on jackstands and place a floor jack under the lower A-arm, then remove the bolts on either side of the arm and slowly lower the jack, letting the arm droop down enough to get the coils out. Is this safe? It seems like there's not really anywhere that the coil can go as it releases pressure and I shouldn't have any problems. Yes? No?
Also, if I do this, as I jack the arm back up after replacing the coil, is it going to be next to impossible to get the bolt holes lined back up to put everything back together?
Thanks in advance,
Mark
Thanks in advance,
Mark
