I'm getting ready to pull off my powermaster and the mounting bracket that has the 4 bolts that attach to the firewall.
If I remove this, will that allow the brake pedal assembly to fall down? Because doesn't the bracket that the brake pedal attaches to also use the same nuts/studs as the powermaster brakcet that must be removed when converting over to hydroboost?
Just wondering before I start tearing it apart of anyt precautions needed.
Thanks in advance!
Thanks in advance!
