Removing quarter windows
Wahoo
Any tips for removing the quarter windows?
How about removing the sail panels to be able to get at the windows?
Any product to clean the goop once I remove them?
Thx
Sail panels: need to remove the rear seat back and B pillar trim. To get the windows out I take out the 10 mm speed nuts and lay down in the back take my shoe off and use steady pressure pressed against the glass and it pushes out every time. Put your shoe back on and remove from the outside. Little easier if it sits in the sun for a bit to warm the urethane but it also makes more stringers.
But you can clean it up with brake cleaner or Goof Off.
