It's fairly easy and the FSM doesn't devote much on it. If you remove the trim piece covering the Radio and HVAC controls (it snaps in so you don't need any tools to remove it, just grab each side and pull on it) you'll see the screws for the mounting on each side of the unit.
Remove the screws and pull the unit out enough to take off the electrical cables and antenna wire then the unit is free.
