I used studs and nuts instead of bolts a few years back after I got tired of this kind of trouble. Never a problem again. I can get my downpipe out in less than 5 minutes--something I've had to do way to often lately. In any case, use studs long enough to go through the flange, but short enough to allow the nuts to still be installed on the ends without interference from the downpipe itself. A little dab of never seize every two or three removals will prevent this from happening again. Plus, installing the downpipe is simply a matter of rolling the pipe into the engine compartment and hanging it on the studs. Just throw the nuts on and tighten. No more trying to line up the damned bolts with the holes while trying to hold/handle the downpipe into the right spot. Counterman.
