Project TNX
- Nov 18, 2006
2 things that baffle me, what is the proper way to remove the main loom from the drivers side firewall, the huge plus right beside the hydroboost?
Second thing, where does that same main loom go under the blow motor, I can't see down there and it is beyond me what is going on down there.
The one by the hyrdoboost had a split cover that I thought was a housing, but the wires are still in that black block covered in dialetric grease and I figured I would ask before doing anything else. Everything else has been straight forward, but that thick main loom from the hydroboost, thru the front of the engine, and under the blower fan is a real SOB.
Thanks in advance.
Thanks in advance.
