Replace tailshaft seal
getchasum
MISSING 2 CYLINDERS???
I know to some this seems like a very simple question but I've never had to replace one & need to.
Can the tail shaft seal in the trans be replace by just removing the drive shaft or does anything else have to come out.
All tips & trick welcomed.... ;)
edited: ok I forgot I got a cheezy TH200-4R manual. You simply remove the drive shaft and use a flat screw driver to pry the old seal out. As for installing the new seal, you slowly tap around the cirumference of the seal evenly.
Thanks dude, I figured it was that simply but thought I'd ask.
