turbojkt
- Feb 1, 2003
Looking for some advice.....Below is what one company claims their reprogrammed PCM will do. I'm a new GS owner (one week) and come from owning a Turbo Regal for the last 23 years....and being able to change the prom in the ECM. Is it a good idea to reprogram the GS PCM for basic mods (Cold air intake, plugs, thermostat, U-bend delete and 3 inch DP?) Or is it a bunch of sales hype??
Standard binary file - $99.99
Ideal for stock to slightly modded cars with induction mods, exhaust mods, smaller supercharger pulley and/or rocker arms - features speed limiter removal, slightly higher shift points (~6,000 RPM)** and rev limiter (6,200 RPM) , proprietary transaxle shift behavior adjustments**, air/fuel adjustments, automatic ignition timing adjustments (+3°), knock retard decay rate adjustment, cooling fan control adjustments (180°), cooling fans on at key-off for 180 seconds, will require the use of premium fuel.
