Results with Razor's kit
Otto J
My car usually on the datalogger showed a increase of 40-50 degrees over ambient at the end of a run
Sat it launched at 61* and stayed there thru out the entire pass,And it showed as soon i lifted the throttle that air temp climbed right to 98*(when the Meth shut off)
I will be doing more testing with more boost the Fri
Thanks Razor everything works great
My car also went almost as fast with 25#s and Methanol
as it did with 30#s without
This was using c16.
This was using c16.
Otto, thats great news. Glad you entrusted the concept and are seeing the results we all have been getting.
Anything I can do from afar to help, dont hesitate and call.
Will you be going to Reynolds in a few weeks?
NO i am saving he car word the nats 05, but one last testa and tune this fri, I am going to do a few runs with an without it loggin intaketemps for a real comparison
Will post results
I am going to need to order a kit soon as the one i have my buddy gave me to use , He bought it from you or Cal last year at the nats
His name was Brett
Now i have to replace it:D
Timing
Otto what kind of timing were you using and what was the et/mph? launch boost? and how did you have the alcohol setup set. PS: My Razor kit should be on the road by this weekend. The only thing "extra" that you see in my engine compartment is a mini overflow bottle and a "black wire loomed covered" braided hose that follows the contour of my black 3" aluminum up pipe, no wires to be seen anywhere. I installed it at the same time that I installed the ME-R chip setup.
