RETORQUING HEADS - When
PaulRV6
I was wondering how long after initial breakin do I retorque the heads? I drove this for about an hour, so is it the right time to do this?
Also, how difficult is it to get the pass valve cover off, it looks like it doesn't come off easy? Any special tricks?
paul
paul
Retorque your heads after the engine has reached operating temperature and stayed there for at least one hour, and then cooled completely to ambient air temperature, for instance after sitting overnight.
IMO you should follow Alan's plan no matter what gasket you are using, it certainly will not hurt
Mike
I am using a composition gasket with ARP studs. Is it or is it not needed because getting the valve covers off does not appear to be an easy task with engine loaded in the car.
paul
Nope. With studs, absolutely not either. The other case would be if you run aluminum heads.
No retorque required with Cometic Multilayer spring steel gaskets.
Mitch
Re-torque after one complete heat cycle. Let it warm up then cool off completely. Don't go driving the wee out of it. The heat causes parts to expand and the gasket to move around. If you create high cylinder pressures, you can damage the gasket prior to the retorque and the damage could already be done.
I have done both, re-torque and not re-torqued. When I retorqued, I found some took torque and others did not. You will NOT be able to retorque all properly just because of the engine sitting in the car. To do it by the book, you'd have to pull the engine. You must loosen completely and then take it back up to torque in one motion. You can't just put the wrench on there and re-snug it. Static friction is much higher than dynamic so your torque reading would be inadequate.
Unless you are using valve cover studs, you can pull the cover off by rotating the cover towards the HVAC box and sliding it forward. Move the oval wire conduit up out of the way first. With my T&D rockers, I was able to re-torque without removing the rocker shaft but you should check the lash anyway as you are changing the valvetrain geometry ever so slightly.
My lockwires are a composition gasket (part steel and part fiber - true definition of composite) and they require a retorque. A factory gasket doesn't require retorque. Check the package your gaskets came in. I believe all competition gaskets require a retorque.
Intercooler, just reading the ARP tech info and it states:
"If everything is right, the stud should be installed finger tight. Then, when applying torque to the nut, the stud will stretch only on the vertical axis. Remember, an undercut shorter stud will have a rate similar to a longer, standard shank stud. This provides a more even clamping force on the head. Because the head gasket will compress upon initial torquing, make sure studs and bolts are re-torqued after the engine has been run."
Not sure why you are saying not to re-torque?
If I decide to re-torque the head nuts, what all has to come off to do this besides valve covers?
paul
The headers have to come off.
You won't be able to properly tighten the passenger side back bolts due to restricted movements.
I wouldn't use a U-joint in your torquing either.
Have you ever heard of a failure due to retorquing? The head gets hot and puts extra clamping on the gasket, compressing it plastically. The washer, nut and stud also wear in their mating surfaces. If you drive it or let it run longer than simply heating it up and immediately cooling off, don't get on it. If you rip the facing on the gasket it will fail early.
I put this in both threads, the other by accident, this one on purpose. If you need more info, do a search on head gaskets. In a couple threads I did some long and serious articles on head gasket failures, retorqueing, over torqueing, and stud vs. bolts.
Well, it's up to the individual I suppose. All I can tell you is that I usually average building 20-30 engines a year, and business keeps getting better, and I retorque the heads ALL high performance engines REGARDLESS of what fastener and gasket are used. It works, I can't remember the last time I lost a head gasket since I started retorqueing religiously.
There is one notable exception. We do have a 391 small block Chevy, on alcohol, with 11:1 compression and an 8-71 BDS blower. The throttle hung, and at about 8500 RPM, it was making in excess of 25 psi of boost. It blew the gaskets out from under the heads. Best I can tell it didn't blow until the last couple hundred RPM.
So that's a total of ONE pair of head gaskets in over ten years. I retorque with ARP studs and Fel Pro gaskets just as often as I do on claimers with stainless shim gaskets and stock bolts. Talk to most any professional race engine builder and he'll tell you he retorques heads his high performance engines. It DOES make a difference, don't let anyone kid you. Fel Pro is selling gaskets for street cars (stock ones) on the basis of not retorqueing :rolleyes: . The Federal Mogul and Fel Pro tech reps told me I should retorque, so did ARP, and so did Smokey Yunick. Good enough for me, and it solved my problems.
I guess I bow out at this point. Do what you want and hold yourself accountable. After all, you will be the one fixing it or not if it breaks. If it works for you, go for it! I am not saying it isn't a bad idea at all. Hell it is probably a fine idea but I haven't had a problem with my torque specs moving on me so this method has worked in my situation. Rather than waste my time on here defending my stance I think I should just sit back and let everyone do their own research:D
Alan's info
Alan,
I kept the info you posted a while ago for reference. Hope you won't mind me pasting it in this thread.
Alan's Quote:
Now while I haven't had a bolt or stud come loose (as in finger tight) with any head, iron or alloy, I have seen a significant reduction (nearly a complete elimination) in head gasket failure with the use of retorquing and also with the use of studs.
First, I don't think the commonly suggested overtorquing works (I'm not saying that you suggest overtorquing, just that it is a common suggestion around here). The reason is that a fastener, especially a high performance fastener like an ARP bolt or stud, is designed to stretch a certain amount, and is in fact a linear spring. Now, when you torque a fastener over a head gasket, you stretch the fastener, and preload it like a spring, and there is only so much stretch and spring left, the the fastener will either stop stretching or fail. Since with the ARP we are dealing with a 180,000 PSI fastener, actual failure is unlikely, so when the cast iron head retained by that fastener expands as the engine reaches operating temperature, it expands somewhat faster and to a somewhat greater degree than the fastener does. So, if the fastener is overtorqued and will not stretch, if it is an ARP 180,000 PSI, either the threaded bolt boss in the block will fail in some manner, or the head gasket itself will be crushed somewhat by the expanding block and head. Now you've crushed that gasket more than it was designed to be crushed (it was designed to be preloaded more than actually crushed) and the gasket cannot return to its pre crushed thickness. This removes a certain amount of preload on the fastener, and weakens the joint. Retorquing here is critical.
Second, as to retorquing, many have gotten by without it. However, when we returned to the old habit of getting the engines to full operating temperature and stabilizing them there, NOT making any power runs on them, and then allowing the engine to FULLY return to ambient air temperature, and only then retorquing the fasteners, we eliminated over 95% of all blown head gaskets on all of our engines, both normally aspirated and supercharged, no matter what gasket or fastener was used. Evidently there must be some crush and taking a set on the part of the head gasket itself, since we measured the fasteners to see if the had permanently stretched and taken a set. We use plain old Permatex 2B sealer on the threads of all BOLTS that enter the water jacket, and to date have NEVER, in maybe 400 or so engines built, had a head fastener leak after retorquing. Even Fel Pro reps grudgingly admitted that their gaskets seemed to perform better when they were retorqued. Not all joints will show a need for it if you just try to take a torque wrench and see if the fastener will turn at the final torque setting, we always break them loose to around 70% of the final torque, and retorque them. I've sat through around 20 or so hours of seminars given by Fel Pro and ARP, with experts such as Keith and Randy Dorton, Spenny Clendenen, Lou LaRosa, Smokey Yunick, and a few others, and the story has always been the same.
Third, on the subject of studs. As far as I'm concerned, there can be no legitimate dispute of a few facts regarding the use of studs over bolts in main and head fastenr applications. Fact one is stress on the bolt boss in the block. A properly installed stud will not overstress the bolt boss in a block so long as the proper amount of preload or torque is applied. Once properly installed a stud only loads that boss in a linear direction that it was designed and intended to be loaded in, and it does not have a rotating wedge effect on the threads. Fact two is the preload on the boss and block in question will be the most accurate preload in both force and direction possible. The better quality and finer threads on a stud WILL generate a more accurate preload. The threads and block will be much less likely to be damaged. In the case of head gasket joints, we've seen a measurable difference in the amount of failures. We've also noted a measurable difference in distortion of the cylinder bore and the deck surface. We have not noticed any difference in the need to retorque. If you install the studs into the block in the proper manner, they will not leak. The only drawback to studs is that they inhibit or prohibit in some cases removal of the head in the car. On the other hand, we've found that coolant of any type that gets in the oil in any significant amount especially while the engine is under heavy load will cause some damage to bearing surfaces, and it is nearly impossible to remove all traces of coolant from the oil while the engine is in the car besides in most cases at least some damage will have been done to the bearings, although it may not be obvious to the untrained eye. In other words, in the rare event that we lose a head gasket, then engine, whatever brand and type, comes out and down for inspection. A few hours labor and some gaskets and possibly a bearing or two is much cheaper than a ruined block, crank and or rod due to an oil/coolant contamination related failure.
We always chase the threads (all of them) in a block before final cleaning any way, and we also clean the bosses out with a spray cleaner like brake cleaner or Loctite prep cleaner before installing fasteners. When using studs, we follow the same prep procedure, and then we measure the studs and mark them with one wrap of masking tape to ensure they are installed at the proper depth. Then a pair of clean heads, with no gaskets, is set aside. We install each stud by hand into the block with a light coat of RED #271 Loctite stud and bearing mount thread adhesive, doing it quickly so that the Loctite doesn't set up, and then we place the head on the block, and torque the head to 35 or 40 foot pounds before the Loctite cures, and we let it cure for 24 hours before disturbing them. This will assure that the stud is sealed and is standing straight up from the deck surface. We've not had a single instance of studs leaking when using this procedure in nearly 20 years.
Regarding the use of alloy heads on both iron and alloy blocks. If you look closely at the catalog, you'll note that ARP often makes a special stud for alloy heads. These studs are a special diameter on the shank, to allow them to have the proper amount of stretch and preload for use with alloy heads which have a much much greater thermal expansion coefficient than iron heads. No matter what you do, alloy heads WILL crush a gasket somewhat, and WILL require retorquing, but these special studs do alleviate the excessive crushing, and will result in a much more successful result.
All of this may have been a waste of 45 minutes, it may fall on deaf ears, and I may be branded an idiot, but it has worked for me over a period of around 20 years of racing and engine building that has encompassed everything from small engines running alcohol and nitrous oxide ( a 16 HP Kohler engine with a 356T6 billet head that made 68 HP at 22,000 RPM), to Super Modified pulling truck engines ( 11.5:1 static compression with 50% overdrive on a 10-71 blower will test your headgasket theory well at 7700 RPM), and everything in between. Take it for what it is worth, and use it or call me a fool. Maybe it will help someone, anyway.
-6PacktoGo/Alan Witter
I torgued mine on the car, let them sit over night and retorqued them Each bolt could be turned further the next day. I will run the car, and retorque them again. Just my .02
I could also get to every head bolt without a universal. Long socket and a 3/8" torque wrench worked for me.
Lets say you are installing stock HG's and stock TTY bolts, you wouldn't have to retorque then...or would you? isn't this the purpose of the TTY bolts?
Bob,
You are talking GN-1's. No?
I have one question. When you mean retorquing the heads, do you loosen all the bolts at once or just one at a time or not loosen at all? That is not clear. Thanks alot, just confused:o
IC, These are GN-1 and the instructions indicate to retorque. I agree iron may be different.
3.8, you loosen them one at a time about a 1/4 turn and then retorque to the specified value.
Re: Alan's info
Originally posted by U1ARUNIT
Alan,
Alan's Quote:
Thanks Mark, I glad I was able to post something someone felt was worthy of saving. That pretty much sums it up. One thing though, my name is Alan Roehrich, as can be seen in my signature.:D
