Been having an issue with my inner valve spring pulling my valve seals off. I have an old rev kit laying around that I can put in, allowing me to run dual valve springs instead of the triples I have now, but I would have to invest in new lifters and pushrods.
I have no idea why I have to run so much open pressure on the valves (close to 800 PSI with a .640 cam), but I do. If I even drop it 50 lbs it shows up on the datalogging-boost drops as rpm climbs. It's only a few pounds but it is measureable and goes away as I add valvespring pressure. Another option is to lighten the valvetrain, but I don't see where that is possible. Titanium valves already. Would something like the Shubeck lifter drop that much weight to ease up on the valvesprings? Any other advice? Standard single turbo stage 2 headed engine, solid roller cam. It is suposed to be a a street roller grind, but maybe it is ground too aggressive?
Greg Kring
87 GN
9.05 @ 150
Greg Kring
87 GN
9.05 @ 150
