no way on a stock longblock.Not on a stock long block. Lol
huh?the 2 wheels arent even close
no way on a stock longblock.![]()
i will put it to you this way the 65f1 flows closer to a 68 turbine wheel.62 turbine flows to about 70#/min... 65 flows ?
nope65f1 is done at 80-82#/min
nope
Not 100% stock...has an old Comp 206 FT cam and the proper springs with arp head studs but everything else is stock. I'm not sure what the rpm range is on the 206 cam but I feel like I could raise the shift point up a little from 5100.Ur guys right thought he had a cam and good spring in there.. 5100-5200 would be good with stock junk.
nopeYour over spinning it then.
3 bolt ex housing and ive made alot more than 800hpwhat housing did you use to make over 800 hp on a turbo buick?
you wouldnt believe me if i told youNo way you made it with a Garrett 63 or small precision housing...no way
3 bolt ex housing and ive made alot more than 800hp![]()
not even close, those housings will do 1100+Yes .85 which is like .9 can make mid 800 .
its been doneJust saying 800 hp .63 pte
