turbojimmy
Supporting Member
- May 26, 2001
My upper control arm ("a-frame") bushings are bad due to the heat from the header and DP.  I searched and found lots of instructions and information about the job.  I just have a couple of questions:
1) No one mentions the dangers of the coil spring decapitating you when you remove the upper ball joint. This is because you jack the car up by the lower control arm, right? The weight of the car keeps the spring in place? My floor jack slllloooowwwwwwlllly loses pressure and lets the car down so I think I'll set the lower control arm on a jackstand.
2) I see people burn the bushings out. Is an oxyacetylene torch too hot? Will I damage the arm with it? My dad has one and we've never used it.
Other tricks or tips would be appreciated.
Thanks,
Jim
Thanks,
Jim
