Oct 20, 2017 #1 R robertf Active Member Joined Mar 21, 2014 Messages 853 So I'm about to purchase an RJC oil pan. Is there any "real" advantage to getting a biggie adapter as well other than a bigger filter? If the oil is changed frequent, is the bigger filter really an advantage? Thanks.
Oct 20, 2017 #2 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,541 It flows better so there's less pressure drop. The real world benefits are more pressure at idle and less bypass oil going around the filter media. It's worth the money if you're still running the oil cooler sammich adapter.
Oct 20, 2017 #3 R robertf Active Member Joined Mar 21, 2014 Messages 853 I've removed the cooler way back. Do I still need the adapter or will a bigger filter fit already?
Oct 20, 2017 #4 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,541 If you don't have the sammich adapter anymore, the biggie kit won't work.
Oct 20, 2017 #6 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,808 you can get still an adapter for biggie filter without oil cooler. its basically a spin on bushing metric inside sae thread outside http://rjcracing.com/product/oil-filter-adapter/
Oct 20, 2017 #7 R robertf Active Member Joined Mar 21, 2014 Messages 853 Thanks for this. I will get that also.
