cottonpicker14
- Feb 17, 2005
Will try to make this short. I have an RJC boost controller and I cant go over 19psi with the test pipe opened or 17psi with it closed. The RJC is turned all the way in and wont go over 19 with the test pipe open.
I have all new vacuum hoses, cant find any vacuum leaks, no knock, 02's normal, blm 132, Razors Alky, no studdering, no missing and spools up fast.
I thought that the RJC would allow me to go as much as 25 but is maxed out now with the 19.
I have the the recommended 1/8 tension on the actuator arm.
Question is, if I turn the adjustable actuator arm in a few turns for more tension, will that increase the boost of the RJC as well or will that have no effect.
Any other ideas would be greatly appreciated.
