rjc boost controller
Under Pressure
HELLO
To those guys running them do you like them ? Do they help on turbo spool up ? feedback please....
I really like mine. My turbo is known to be laggy. I could tell a difference once I installed it. It wasn’t as noticeable as when I put the higher stall converter in, but it defiantly made a difference in my set up. Plus there cheap!
Good luck.
It's not really a matter of opinion. It stops the wastegate from bleeding off pressure earlier than it's supposed to. It will help spool-up. Whether or not people "like" it is just a matter of whether or not they know what to expect from it.
All I know is since I put it on the car blows the radials away alot easier and gets sideways.
Put the controller on and it spools a lot faster! Zero issues here.
It made a big diffrence on my 3.8 and i know i run turbos that are technicaly too big (like theGTQ74 w/85 exh. or 80mm bb). Stops boost creep and They both spool great and pull like mad.:D
Best bang for the buck helped my TE45A after about 10 lbs pulls like a freight train love it
I have heard all the same, I will be installing one upon reassembly.......Could be a while though, post me on how it works for you!
boost
do you get more boost by screwing it in or out can you still use t controller in the car for higher boost
should i take off the boost adjuster that i have in the car its just a t vavle to let air out
