626gn
- Feb 15, 2009
RJC Down Pipe Block off Plate (part #RJC-DPBOP). Only difference is this one has a 0.875 wastegate hole already drilled (exhaust hole measures 2.6875). If you are not currently getting a good seal between the wastegate hole on your turbine exhaust housing and wastegate puck, this piece should fix that. The hole I drilled is small enough where adjustments to your particular application should still be possible if needed. Will not work with a stock elbow. $28 shipped no PayPal fees.
http://rjcracing.com/product/exhaust-systems-2/flanges-weld-bungs/
