RJC pulley sfi balancer and HD wastegate
turbo6man
OK the RJC pulley is the race pulley and it works great. See pic $110.00 shipped
Second is a TA performance sfi balancer. This thing has less than 500 miles on it and is in great shape. I removed engine and doing an ls swap. This pulley was balanced for my setup. It was balanced (drilled) ONLY on the removable weight soo the following will apply:
1) If you are running an aftermarket crank, you remove the weight anyway so it has no effect on the balancer.
2) If you are balancing your assembly, your machinist will balance it again anyway.
3) If you want to put it on a stock balanced setup you will need to contact TA performance for a new weight and you can bolt it to the balancer and install it on your stock application. I paid $289.95 plus shipping I will sell it for $189.95 shipped
The last thing I have is a like new HD wastegate actuator. I ran it for only a few hundred miles when Bison on this board loaned me his Turbonetics 6688. I bought this from jack cotton for $99 will sell for $70 shipped
ill take the pulley and the balancer sending a pm for payment info
