RJC Stainless 3" Downpipe (See Pics, )
m233roller
Banned
Here's a stainless steel RJC 3" downpipe. It was about an inch short for my Terry Houston test pipe (which is 12 & 1/2 ins. over all length) so instead of just adding an inch I cut it back and added 3" and put a wide band bung down low. Pipe has one small dent on it from frame hit (see pic.) but is still a nice piece and has that monster 1 & 5/8's. puck. I paid $490 plus shipping for it. Selling for $350 plus shipping and paypal fees. Only ran it last summer.
Thanks Mike
A free bump. Anything Mike sells is always top notch. Speaking from personal experience. GLWS
What kind of clearance did you get with the wideband mounted down near the cat? Was it easy to access? Also, do you have a test pipe too?
87 GN, resurrected at 120k miles
Fresh Stock internals, turbo and down pipe. Rebuilt stock tranny and converter.
50 lb injectors, Kirban's high perf fuel pump with Hotwire kit and billet AFR
Maft-Pro, speed density mode, boost and timing control
Hr parts motor and Trans mounts and rear sway bar.
Poly front sway bar, end links and body to frame bushings.
