ROAD TESTED IGNITION MODULE $59 SHIPPED
Boxcars
Banned
AFTER MARKET IGNITION MODULE (used) FOR 1987 (only) GRAND NATIONAL - TTYPE. --TURBO V-6
ROAD TESTED WITH A KNOWN GOOD COILPAK TO MAKE SURE THEY ARE 100%, WITH ZERO PROBLEMS STARTING, SMOOTH IDLE AND ACCELERATION, AND NO, SKIPS, NO STUMBLES, OR ANY OTHER ABNORMALITY, MOST IMPORTANTLY, AT WIDE OPEN THROTTLE. (through the gears @ 25psi) -- ALWAYS WISE TO HAVE AN EXTRA, KNOWN GOOD, IGNITION MODULE --
3 UNITS AVAILABLE
$59 SHIPPED to continental US
AFTER MARKET IGNITION MODULE (used) FOR 86-87 GRAND NATIONAL - TTYPE - 89 TURBO TRANS AM. --TURBO V-6
3 UNITS AVAILABLE
the module that you sent will not start my car! and the coil is new and functional
Hey Bob, I already responded to your earlier email. Sorry for the inconvenience. I'm sending out another one as you requested. Are you quite sure you wired it properly? I check them repeatedly for restart, but sometimes there's problems from car to car.
AFTER MARKET IGNITION MODULE (used) FOR 1987 GRAND NATIONAL - TTYPE. --TURBO V-6
3 UNITS AVAILABLE
Ill
Take one
In reference to Bob Brady's problem above, neither one of the modules I sent him started his car, nor did brand new in the box aftermarket ignition modules he purchased from Kirban start his car. Finally, he purchased a Delco unit which started his 86 right up. It's possible these aftermarket units don't work on 86s. Not sure yet as I have to find someone local with an 86 to know for sure. Each of these units I'm selling I road test not only on my 87 Grand National, but also on my (87) GN powered El Camino. So, it seems there is no problem with 1987 models. TIA
