I was told that there are 3 standard stage 2 rocker arm ratios. 1.55, 1.64, 1.70.
I will be ordering a custom hydraulic roller through comp as soon as I figure out exactly what I want. Comp has more than half a dozen lobe profiles around 220 degrees duration. 220 is the duration range I decided to go with. Now heres my question:
What is harder on the valve train, getting the lift your looking for in the lobe or getting it with higher ratio rocker arms? Depending on how aggressive the lobe is and which rocker ratio I choose I can get a 220 or so lobe with any where from .512 to .578 lift.
I'm looking for a low maintenance valve train. I don't want to have to change valve springs all the time and stuff like that. So should I go with a low lift lobe and a higher rocker ratio or vice versa? If it was up to me right now I would just go middle of the road with both because I not sure.
This cam will be for a 270" stage 1 short block with ported stage 2 heads.
P.S: any input on lobe separation angle? I leaning towards 112 to 114.
TIA: Jason
TIA: Jason
