rocker arms
garrett
I have a 84 turbo motor with Kenne Bell iron heads. I was taking the heads off to re-do the head gaskets the other night. I noticed that two of the little plastic retainers that hold the rocker arms in place on the rocker shaft had broken. I went to my attic where I have a set of 87 stock rocker assemblies. I was going to use them in place of the ones that I took off the 84 motor. When I compared the two side by side, I noticed they were alittle different. The ones on the Kenne Bell heads are alittle bigger. They are stamped L and R on each set. I don't know if they are a different ratio or if they are a reproduction/heavy duty assembly made by Kenne Bell. Does anyone have any input? Does anyone know where I can get the plastic retaining buttons that hold the arms in place on the shafts?
Can't say I've noticed different sizes before ...but I have purchased stock replacements from Auto Zone before. :) one at a time :)
retainer
Did you get the plastic retainer from the auto parts store as well?
Quicksilver
Ed from Orchard Park NY here....
Did you have your machine work don by Bob at B&F?
