Just get a grade 8 bolt and it'll be fine. You don't need any 'custom turbo Buick' bolts there.
I will strongly recommend some rocker saddles though. As you've seen with your own experience it's not a good idea to have the bolt touching the shaft in two small points instead of holding the shaft itself.
