Rocker shaft
rb68rr
What is the proper procedure for tightening the 3 bolts on the rocker shaft?
I would just start in the center and then pick a sequence (ex. 2-1-3) and then torque each bolt in 5lb increments repeating the sequence. Works for me. I believe spec is 25ft lb.
