Larry Smith
- Nov 30, 2001
I put some M/T 28x12.5x15 ET streets on last night. Weld wheels, 15x8 W/3.5 backspace. No clearance problems inside, but unless I air up my airbags to 20lbs, they are rubbing on the outside under a hard launch. Soooo, I need to roll my fender lip. Question. Do you remove the wheel lip trim? Do you leave it off or try to roll it too and re-install? Most say to use a baseball bat against the tire, but the tire is soft and it just deflected on my initial test. Any hints or comments welcome.
Thanks,
Larry
Thanks,
Larry
