SignUp Now! )
 )Anything over .510" net valve lift, will be too close on the exhaust side on a stock set-up. Be sure to factor in valve loft if you have only 90 lbs. of seat pressure. THat is the valve can be "thrown" farther open tan the cam is opening it. If there is low spring rates, then the valve will open farther than is advertised, at high rpm. I find that the hydraulic roller setup at stock ratios, is too close on a stock head. (at least for MY standards.) Typical lift with stock ratio is .517", and that is too close for stock retainer to guide clearance on the exhaust valve. Some guys run it as-is, but I don't like it. Time for stainless valves, and good seals. (AND good port work, too)
thanks guys how about push rod length
