thepremier
- Dec 31, 2005
I am having some problems with my GN, but I can't seem to figure out what exactly is the problem. The car has a really rough idle, and at times the car will sputter for a couple of seconds when I take off from a stop position.
I have installed a new AC Delco Ignition Coil & Module, along with brand new MSD Plug Wires and spark plugs. TPS is set to .45, today I just installed a Fuel Pressure Gauge on the fuel rail, and it gave me a reading of 34 PSI at idle. Does this seem to be in the correct range at idle? The car has new 50# injectors from Precision Turbo along with a chip to match. The fuel filter is fairly new and doesn't appear to be going bad, the car does have the stock fuel pump, and I have the Walbro FP + Hotwire coming from Racetronix on Friday. I have a feeling that the stock pump is not getting the job done, but I cannot be sure until I install the new pump and hotwire.
I was also wondering if it could possibly be a problem with the Fuel Pressure Regulator. It is an Accufab regulator, but it previously installed by the owner when I bought the car 2 years ago. What are the signs of a bad Fuel Pressure Regulator, how would I go about diagnosing if it needs to be replaced?
All help would be greatly appreciated.
