Hello,
Just got one of our engine rebuild projetcs started tonight. Good oil pressure and quiet running, BUT....I have to pump the pedal to keep it running..it won't run if I let off pedal or hold pedal steady. It's also backfiring slightly once in a while. Reminds me of a carb'd car with a huge vacuum leak, like you left vacuum plug out of manifold under carb, but we can't find any large holes.
Injectors have been sitting in the shop for about two years; worked fine last time they were in the car, but I thought maybe they all haven't come to life yet..only ran it for about 3 minutes at 2-3K rpm.
Every so often you could hear it run normally and it was smooth and sounded fine, but the misfiring and constant pedal pump are obviously not normal...plug wires checked and they are on the right plug.
I used a Casper cam tool to set sensor....we do NOT have the factory boost solenoid hooked up yet, but I didn;t think that would cause my problem. I am still not real familiar with all the hookups and hose routings, but everything appears to be hooked up and no noticeable vacuum leaks that would do this.
I know it's hard to diagnose a car without being there, but any gross errors come to mind when seeing these symptoms.??
Car has been sitting for 2 years with engine out; all electrical seems to be working fine; Scanmaster lights up and gives readings.
edit: just remembered the chip in the car was for 60# injectors and I have #36 in there now; I will swap chip in the morning; do you think this could cause all the comotion??
Thanks for any input,
Bob
Bob
