I just got my Scanmaster unit the other day and pulled the numbers off of my TTA. When it is cold or has just sat over night I go to start it up it starts up and surges up to 2K rpm then it will drop to 1K, then up to 2K again, then start dropping down to 500 rpm and surge back. It will do this many times and usually die once or twice until it warms up. I have to feather the pedal a few times to keep it from dying. The car is all stock, has 198K miles, and runs strong around town and even better on the highway, but it has a rough idle which I have heard is normal for these cars to an extent. How rough should it be?
Here is what I have done so far, full tune up with MSD wires, NGK TR5 plugs, new AC Delco 02 sensor, new ACD IAC, cleaned out the intercooler, replaced all the vaccum lines, put on an Accufab AFPR set static PSI to 40, put a new ES trans mount on it, new ACD coil pack, and ACD new ignition module. I did the IAC reset procedure the other day and the TPS is set at .44 at idle. I checked my fuel pressure and it is not dropping even after 5mins so I believe I do not have any injector leaks. Here are my Scanmaster #'s
O2 113-768-126-843 (they are all over the place at idle, with it rev'd up to 1.5K rpm it reads 76-85.)
AF 07
L8 38-41
Bat 14.3
Int 140
BL 150
Clt 154
r 825-850
TPS .44
IAC 44 (I know this high, how do I lower it?)
_
I I AL 00
I am still new to the world of self diagnosing/tuning so any help is greatly appreciated.
AF 07
L8 38-41
Bat 14.3
Int 140
BL 150
Clt 154
r 825-850
TPS .44
_
I I AL 00
