I'm a road racing guy.But,I have taken the car to the track a few times with a best time of 13.20.I think it can do better but I don't beat on it.I had the original radiator recored by a racing specialist.I run a 180 degree thermostat and have no overheating problems.It usually runs 190 on hot days.A good clean TR7 radiator usually works fine for a V6.Make sure you're not clogged anywhere.It also helps to install larger diameter water necks.I use a flexfan setup.I've seen electric setups that work also.You might want to try to modify a shroud off an old Monza or Starfire.You should be able to get this car in the 12's easy.I think your gearing is way high.The stock 3.90 rear would give you better results.I have run the 3.90 and a 3.45.I can only get about 115 out of the 3.90 with an overdrive tranny.So,I would imagine that your engine must be screamin for Jesus.The 3.45 is the best.Good acceleration and 140 top end.Your headers sound similar to mine.I run an Edelbrock (Carter) 500 on a stock aluminum manifold.In case you haven't heard,these units perform every bit as good as the aftermarket and are a lower profile.I know a few guys who run 600's but the general consensus is that is too much carb,unless you had some serious head work done.Hope this helps.By the way,nice choice of car.I'm partial to the convertibles myself.
