5500.. at 110 ,locked....
assume thats in 3rd gear
3.42 gears?
what did you get the rpm info from ?
whose (what) converter
if you are locked and the lockup holds than what the converter efficiency is has no meaning as you should be 1 to 1 (zero slip)
but if the info you posted in 3rd ,locked and rpm is accurate .... your lockup clutch isnt holding as slip is almost 15%
it looks like you are trying to lock a converter that wasn't built for WOT lockup
locking up a converter that is slipping the lockup clutch is very bad thing to and generates a lot of heat, much more heat than 15% slippage non lock converter
a good non lock is under 6% slip but ive seen art carr 9" nonlocks slip from 15- 22% depending on power applied
now if you race unlocked or your lockup doesnt hold than you will trap with more rpm
locked up (zero converter slip) with 26 tire in 3rd... 115mph should trap 5100
with your 15% slip thats 5750 rpm for 115
115mph will need 450hp at 3700lb race weight,
injector duty cycle should be around 60% with 60 motorons
