I am replacing the rubber brake lines that go into the caliber . The probelm is that I have both cooper shims on the passenger side but on the driver side it will only bleed with one cooper shim in . Is this normal ? I know the hole in the bolt must line up but when I have both shims in its not . Please advise ints 29 degrees and 2 in the am butI am determined to finish
