Jan 24, 2014 #1 E Ed Valvo Member Joined May 25, 2001 Messages 856 I hear it is bad to run a non-LU convertor in a LU trans but what about the other way around? Other than the lack of efficiency, it is ok to do?
Jan 26, 2014 #2 TexasT Texas, Where are you from Joined Sep 10, 2002 Messages 7,209 you really need to mod the pump if you plan to run a non lock up. And then if you want to run the lock up put the lock up valve in the pump to go that way. Just works way better when you use the correct parts for the converter you are running.
Jan 27, 2014 #3 J Janis Transmission Member Joined Jan 11, 2014 Messages 42 If you use a L/U converter in a non L/U TRANS it will lock the clutch when you put it into gear
