TurboTommy
Carless Loser
- May 24, 2001
Yeah, I know this is retarded; just hear me out right now.
I need to smog my car in CA and to do so I need the stock turbo on there, mostly because of the valvecover breather. Since the compressor on my stock turbo is in terrible shape, I'm going to run a bolt through the turbo where the shaft would be and put large washer, or something on either end to keep oil in (with RTV.) Assuming this works, the car will be without turbo for a while.
Now the question is, running the motor N/A even with a 91chip, do you think it could run off 87? And could running 87 effect emmissions possitively or negatively?
For the most part, I am just currious. I figured 87 would work fine in 8.5/1 compession, even with timing from a 91chip. Also, I was thinking that 87 would run hotter and if hotter -- cleaner. I don't really know for sure. Tell me what you think...
