Wagondraggin
2nd ugliest car on d site
- Feb 16, 2003
my engine is running rich... cant figure out why...my car has no mods besides nitrous 16lbs boost.... since this started i've tried changing the o2 sensor (twice)... new air filter... new fuel pump (needed it anyway had nothing to do with this problem) could my tps be bad??? would this thow a code if it was bad? could the tps cause my car to run rich?? since this problem started i've had uneven idle (up down up down you know the routine) and a really strong fuel smell (no leaks)and it stumbles a little when i accelerate from a stop . i'm getting about 30psi at the rail at idle. and no lights or codes from the computer... i'm stumped any ideas?? i have an 85 hot air motor and trans no mods
