Just got motor in and fired up. At first I had some some valve train noise and about about ran an ad for the car. I had a friend come over to listen. After several start ups and a few minutes running, it quieted down. I guess there was a lifter that took awhile to get some oil. I don't quite uderstand the whole preload stuff. I put the lifters and pushrods in the same place as I took them out. I had no problems before. I am going to go back and check all my hoses and wires. If I didn't set the cam sensor right, what kind of symptoms would I have? I want to try to eliminate as much as possible in my house on the computer before I go back out in the 105 degree Texas heat.
