BlackMetal
- Sep 29, 2005
I'm not gunna be doing this until it gets a bit warmer out, but I've decided that I'm not worried about racing my car at the track, and I'm not gunna worry about some extra weight from woofers and an amp.
Is there an existing opening into the trunk that the power wire could sneak through, or should I plan on having to cut a hole? Also which is the best path to get it from the battery to the rear of the car? I know for my upgraded fuel pump I ran the wiring through the frame and it worked out good. Could I do something like that?
Also I assume drilling is required to securely mount the sub box? Any tricky ways to keep it in place without drilling into the body?
Earlier this year I replaced the stock speakers and installed a new headunit but I've never done anything involving subs, so I'm sure I have some extremely amateur-ish questions.
