Finally got the car back together after rebuilding the front end, started her up and went to put it in reverse and the brake pedal went right to the floor. Smelled brake fluid and right under the drivers door was a huge puddle...
Anyway, the line from the prop valve to the rear has a hole in it, planning on just getting the pre-bent ss line from Classic Tube but was wondering is it just one solid piece from the valve all the way to the rear hose? Anything I should know as far as routing the new hose before I get into it?
