Sep 7, 2015 #1 C crashedout1 Active Member Joined Feb 23, 2011 Messages 439 Will it work with 84/85 ecm?
Sep 7, 2015 #2 blackazz Not a Gn TurboBuick.Com Supporter! Joined Sep 1, 2008 Messages 1,703 Nope.only 86-87. You can put a 86 -87 ecm witch I suggest doing.
Sep 8, 2015 #4 C crashedout1 Active Member Joined Feb 23, 2011 Messages 439 Thanks but how hard is it to wire in the air temp sensor?
Sep 8, 2015 #5 T TurboDave RIP DAVE Staff member TurboBuick.Com Supporter! Joined May 24, 2001 Messages 14,013 crashedout1 said: Thanks but how hard is it to wire in the air temp sensor? Click to expand... You can't wire in a temp sensor to the Scanmaster 2.1. It gets all of it's data from the ECM via ALDL data port.
Sep 8, 2015 #6 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,676 the air temp sensor gets wired to the ECM, and its not difficult. But the air temp sensor data is used very little in the ECM software, so you can have a chip made that ignores it and turns off its trouble code. Bob
