Hi all,
I just installed my new Scan Master and have a couple of questions as I' m just learning to tune.
1. What is the difference between scanmaster 2 and 2.1?
2. are o2 volts supposed to fluctuate while just driving around?
I noticed the readings bouncing between 200's to 750 and anywhwere in between while at cruising speed. When i gave it about 3/4 throttle they settled at around 800 which i know is too rich. I dont have an adjustable wastegate so I can't mess with the boost, should i turn down the fp? I have it set at 44 vacuum line off. It seems hard to watch the boost gage, the scan master and the road all at the same time!!
Thank you for helping.
