Fantastic that was the answer i was looking for.thanx for the clarification TNT!
Here is a new one I switched the third toggle to off and my rich o2 code went away??? I finally figured out what injectors I have now I gotta see if thrasher will take back the unopened stock injector chips for 2 868 chips.
Now I gotta found out how to identify the turbo! It seems the last owner or the previous one threw a lot of money at this car then gave up and i cant get any info on it.
There are a lot of upgrades on this car and I dont know if they match correctly.
Upgraded turbo(last owner had maintenence work done and they said it was a te-44(checked with turbonetics web page and they dont offer a 44, but it is definately a turbonetics turbo)
RA93 chip(runs like crap),Plenum spacer,868 injectors,upgraded pump,hotwire kit,K&N,chrome up-pipe and maf pipe,AFPR(at least i think it has an adjusting screw on top, but is made by Bosch),flowmaster cat back(I know),braided trans lines,high stall non lock up converter,shift kit(shifts hard),boost gauge knock sensor gauges,fuel pressure gauge on rail.
With all that I bought subframe connectors,LCA'S,panhard bar,LT1 3" MAF($10),translator+,scanmaster 2,and two thrasher chips (for stock injectors that i gotta return).
Right now I can only boost to 10 then it drops to 8 then maxes out back at 10(checked the hoses,adj. the rod,cant get anymore boost).
It is running rich BL is anywhere from 99 to 115,interregator is anywhere from 115 to 131, fuel pressure is set at 45 psi.The only thing I can think is that the chip is for stock injectors and the larger injectors are dumping to much fuel.
Anyone in northern NJ that has and is knowledgeable with TTA's and wouldn't mind going over the car with me I'd really appreciate it.
Sorry this post is so dam long
Pete
