scanmaster doesn't work anymore?
86grdnatl
On my way to work at 6:30 this morning my scanmaster was working normally. But when i was leaving, i started the car and saw that my scanmaster isnt working. It's not lighting up or anything. When i got home, i checked to make sure everything was still connected and plugged in and everything looks alright. Has this ever happened to anyone else? and does anyone know what i should do? Thanks alot
Make sure power is going to it, if you plugged into an IGN port on the fuseblock there is usually a corresponding fuse protecting it. Verify with a voltmeter and make sure it is still connected to the ALDL port under the dash, and if all else fails you can contact Mike at fullthrottlespeed who makes the SM.
